So I'm going to do the work anyway. The Durango is at 200k and it's never had any major engine work. It can't hurt to be done.
I was getting a bad O2 sensor code/reading but I replaced it and it's been clear ever since. Well, it didn't clear immediately after sensor replacement... It cleared after I installed cold air intake and Flowmaster. Not sure if related. But needless to say O2 sensor code is now gone.
The only code I'm getting is "Cylinder 4 Misfire".
She misfires at low idle.... this didn't start until the code popped up.
Intake looks clean and dry. No performance loss besides mpg. She's always burned oil since I bought her at 188k miles. Maybe a quart in between oil changes? Maybe a bit more? No leaks. Seals look good. Oil looks clean. No blow-bye. I've read that typically you end up with more than one misfire code and that it's not usually cylinder 4.... thoughts?
I've done a full tune up. I've checked compression. I swapped injectors. I bought a new coil but I haven't installed it just yet.... will do so when I do the intake gasket. You guys think I'm on the right track? A buddy thinks it's probably a bad valve.... but... idk man... help me out. What else could I test or look out for? To test my intake gasket theory... I ran an entire can of the foamy spray Seafoam directly into the intake while it ran at about 3k RPMs... the check engine light flickered and then shut off for a bit. It came back on after about 15 miles. So that misfire has to be related to something - I would think!
The Hughes' plenum kit would/should fix that, right?
Read my next response... more updates including the Hughe's intake upgrade and I STILL HAVE THE SAME CODE!! HELP!!!!
