61 - 70 of 70 Posts
The fronts will also fit an R/T with a little modification. Mopar doesn't make front splash guards for the R/T so I purchased and installed a set of the fronts from ZL1addons.
I'm about to order a set of these soon for my 18' R/T. What did you have to do to get these to fit in the front? I would also like to get the rears, did those not work for you, or did you not try them?
I've got front and rear ZL1's on my 18' Daytona, mostly because I've got a stone chip or two on my drivers door from the front tires. Anyways, on the Charger they make an SRT, and non-SRT version. I wish they did that with the Durango as well.
I ordered a set of front and rear today with their Memorial Day sale code: Save12 giving me 12% Off from ZL1 Addons. I'll try and remember to update everyone on how the install and fitment goes for my 18' R/T.
Why would you post this in the SRT forum?
I didn't realize this was SRT only. There were several others in this thread asking about the R/T, and I just responded to one of them here hense my response.
I'll just start a new thread for these once I get them, thanks for the heads-up!
Reactions: CaptMoe
That would be better just to avoid confusing anyone. These trucks may seem similar, and in many ways they are, but they are still equipped differently.
Thanks.
Sorry I just saw your post. I didn't have to do much to the fronts to make them fit. I did trim the inside where it curves and meets the inner fender liner with my Dremel to make them line up better. Other than that I was able to make them fit. I also put one screw near the bottom of the splash guard so it attaches to the end of the rocker panel to make it more secure. I'm not trusting the clips without also having something that isn't going to come off.
I don't have the ZL1addons rear splash guards. Instead I have the Mopar splash guards. They fit the rear of my R/T fine. The fronts however would not fit. Since I already had the Mopar splash guards I didn't try the ZL1addon rear splash guards.
Thanks.
They are the same splash guards. Plus this is where the thread about them is located.
Sorry I just saw your post. I didn't have to do much to the fronts to make them fit. I did trim the inside where it curves and meets the inner fender liner with my Dremel to make them line up better. Other than that I was able to make them fit. I also put one screw near the bottom of the splash guard so it attaches to the end of the rocker panel.
Cool, I appreciate it! I'll let everyone know how the rears go in the next few days or so in a new thread as mine are on the way.
Regarding the R/T and others vs SRT, this is an SRT thread, and as @CaptMoe pointed out, their fenders are a bit different on this version. I have no problems starting a new thread for the other models as the SRT version has a fender flair that the rest of the lineup doesn't. Hopefully ZL1 Addons will eventually make them for other trim levels of the Durango lineup.
You are welcome! Yes I'm interested in hearing how the ZL1addon rear splash guards work on your R/T.
And I think starting a new thread for us R/T guys would be the way to go. I still can't figure out why Mopar doesn't make front splash guards for the R/T. There must not be enough R/Ts for Mopar to spend the development costs.
61 - 70 of 70 Posts
