2011 Crew with stock halogens
HID kits installed in fogs, low beam, and high beams. All have HID relays installed, all connected to same ground, and same positive point (pos lug on TIPM)
Fogs ALWAYS turn on with it set to AUTOMATIC, sometimes the low beams will not come on... I have to flick the headlight switch quickly off then back on for them to come on... NEVER have a problem with high beams coming on either..
Last night, started D, and fogs came on but no LOW beams... messed with the headlight switch for about 5 minutes and was finally able to get them to come on... Same deal this morning early when starting it up... had to mess with switch for about 5 minutes before I could get them to come on..
Testing the lights and checking things over in my garage today.. they still had a little issue coming on, but got them on a lot easier than the previous 2 times..
This is BOTH LOW BEAMS, not just one side... so I have ruled out ballast and of course bulbs since they do light up...
And as mentioned above, all 3 sets of HIDs share common ground and pos post for the HID relays...
I'm stumped?!?!?
any suggestions?
I'm stumped?!?!?
any suggestions?
