Time for Hubs
2.3K views 9 replies 7 participants last post by  GolsonMolson
Installed Hub Assembly
TOOLS USED
  • 3/4? Deep 1/2?? Drive Socket- Lug Nuts
    Slip-jaw Pliers- Cotter Pins
    32mm Deep 1/2?? Drive Impact Socket- Hub Nut
    7mm Hex Bit 3/8?? Drive- Caliper Pins
    13mm Flex Head 3/8? Drive Socket- ABS Shield Bolts
    8mm Flex Head 3/8? Drive Short Socket-
    ABS Wire Mount Bolt to Steering Knuckle
    21mm Short 1/2? Drive Socket- Hub Bolts
    21mm Flex Head 3/8? Drive Short Socket- Hub Bolts
    Torque: Hub Bolts 123 Ft. Lbs
Items needed
  • Cotter Pins (2ea)
    Tree Plugs (2ea)
at 200K service.
Good to hear from you Wayne.
GolsonMolson said:
A loud groan turning left quiet turning right. Is that the Passenger side or Drivers side front bearings? Can never remember.
Does it happen when you turn left into the Package Store parking lot? If so, then it might be the wife :)
Seriously, it's usually the bearing that gets loaded (see? package store?) so if it groans turning left, it's likely the right bearing (that's where the weight goes)
?tom
