1 - 9 of 9 Posts
Shayb39
Just got my 04 Durango serviced and they recommended a world of fluid flushes. I asked a few mechanics some say do it some say dont, but none of them own Durango's so I figured my Durango fam should know what to do. :cool:
Don't flush the trans. You can flush brake, cooling & power steering systems.
Those should be done annually, and don't forget the Limited slip additive for those of you with a Limited Slip Differential in the rear. You should also include the Transfer Case with them.
Of course I you go mudding a lot, then do this more frequently.
Ah, I wouldn't consider differentials or the xfer case in the "flush" category.. to me they are in the "change" category, like engine oil..
Drop all fluid in diffs and clean. Refill fresh fluid.
Trans drop pan, change filters, Refill to spec
Agreed whole heartedly.
Discussion starter · #9 ·
okay so what im getting is do all the flushes except for the trans and ill be good. thanks Durango Fam
1 - 9 of 9 Posts
