1 - 1 of 15 Posts
This section will deal with the shift boot.
The shift boot-
The top handle's boot has a different shape than the 2014-17 opening. I measured the circumference and designed an adapter roughly the same overall size and height, but a different shape. The first attempt I made didn't fit well into the opening, plus the piece for the boot was slightly too large.
After giving this some more thought, I decided to use a lighter version that could easily be snapped into / out of the bezel like the 2018+ part so you can remove the handle if needed while the boot is still attached to the mounting piece. I also raised the boot attachment point by a couple of MM to hold it better, and reduced the OA circumference so the boot can install easier. My original design was too sturdy for easy removal. The new design only has tabs under it to locate it, so it can be snapped in or out more easily:
It took two tries, but I think I have it about right now. The first one snapped in and out too easy, and it would have rattled. I have tried the latest version with the shifter bolted in place, and I think it will work as needed. I just need some glue to attach it to the boot and that should do it. Here are some pictures of it:
Underside installed:
Top view installed:
Underside view:
Thank you for the detailed/advice and conversion procedure. I like your adapter.
1 - 1 of 15 Posts
