2015 Durango RT headlight question
1 reading
18K views 7 replies 3 participants last post by  Skippy426
Passenger side headlight is out. I did a quick google search for a replacement bulb and it was confusing given all the options. I would just like to replace that bulb with the OEM bulb or one similar that matches the other headlamp color, etc.
Any suggestions?
Plus, how difficult is it to change the headlight on the RT? I have replaced the turn signal on the driver's side, which called for removing the air hose, etc.
Thanks in advance!
#2 · (Edited)
You must replace them in pairs. Hid headlights change color as they age and get dimmer. Go to theretrofitsource.com and buy some D3S bulbs of your choice, I very highly recommend the Osram CBI bulbs. They're super easy to replace.
Use the access panel in the wheel well... Remove dust cover, unplug the connector, unlock and remove light. DO NOT TOUCH THE NEW BULB ON THE GLASS!!!!
I don't think it's a must to replace both, but the brightness and color may be different.
That is why most people replace both at the same time.
One one fails the other is generally right behind it. But yes, color and brightness will be different, especially with HID.
My factory bulbs were 4300k, but they were so old they turned more of an 8000k, they were bluer than my 5500k bulbs!
