1 - 4 of 4 Posts
wheredogsare
I'm getting frustrated as hell with this. Every forum says to do something different. Please help me out. My 2002 Dodge Durango has the driver's side headlamp and tail light out. Could someone help me out with this? Thanks, in advance.
Discussion starter · #3 ·
I assume you have a voltmeter...as you're going to have to check the bulbs to see if they are good, and then the connectors to make sure the bulbs are getting power.
Have you done that?
Yes I have done that. Bulbs are good. I found a post on another forum about a 2002 Durango, like mine, with driver's side headlight not working. The "solution" reply post said that the headlights are each powered by a different fuse. There was even a photograph of the fuse box, where he circled the fuse to replace. I went to my fuse box, and it's layout was completely different than mine. I looked at the legends for both of my fuse boxes, interior and under hood. Neither of them show a fuse for headlamp or headlight. Do you know which fuse it is?
1 - 4 of 4 Posts
