Whenever I bought my durango I noticed the coolant was orangish and thought it must be a different type of coolant or some corrosion in the radiator underneath it that’s making it appear that way. Regardless I was going to do a flush
Upon buying my first jug of g0-5 I discovered it was actually more yellowish.
Once I drained the radiator I discovered the coolant was was very orangish very similar to dexcool I’ve used in my gym vehicles.
I assume the coolant was dexcool.. which isn’t correct for these vehicles. Instead of doing an ordinary flush should I do a chemical flush? For example the prestine flush ?
I’ll also be doing the thermostat while I’m at and and now considering the radiator due to the amount of corrosion I can see at the top
