1 - 3 of 3 Posts
Hi I doubt it being related but here it is, a rear flasher bulb need replacement, stoped the car, then 30 minutes later, press the brake pedal, but nothing appends.
On the screen, press brake pedal and start.
In the mean time, nothing else works, door lock, lights, rear door opener.
Then as i was getting ready to unplug the battery to reset the ecm, everything started working again, and started the engine. Then a red led on the left part of the inst. Cluster flashed for 5-10 minutes.
I had the BCM replaced 2 weeks ago by the dealer.
Durango 2018, Gt 3.6l engine 94000km
Thanks
It sounds like something is loose. Have the dealer recheck their work and those connections.
Discussion Starter · #3 ·
Surprisingly, i removed the tail light unit to change the bulb, only to find out dodge had a brilliant idea to make it into a 700$ + sealed unit,...
But i simply put it back and it came back to life...
No visible corrosion on the connector though.
Thanks.
1 - 3 of 3 Posts
