1 - 10 of 10 Posts
I have a 2012 Dodge Durango Citadel with about 140k miles. A few days ago a warning message popped up saying that the blind spot detection and parking assist were no longer available. The compass no longer works, just displays as two dashes. And the backup camera is just black whenever in reverse. Before this it's never given me any problems, and with so much happening at once I don't even know where to start. Could all these issues stem from the same point? Any help would be appreciated.
Edit: On the way to work tonight the service awd system alert came on, and the headlights started to flicker.
Agreed....I have a 2013 Citadel Hemi with the original battery. About to replace it with a new NAPA AGM battery this week. Almost 7 years old.
Have you measured voltage at the battery? Both with engine off and while running/charging.
Have you checked for any trouble codes with a scanner?
Replaced the battery. Nothing has changed.
Its not throwing any codes as far as I know. Just the warnings.
@JimmyEjr :
Check M34 fuse (10A). Park Assist Module/Climate Control System Module/IR Sensor/Compass Module all those run on that circuit. I just narrowed mine down with the help of the scan tool. My rear blower circuit was short to ground which blew the fuse.
1 - 10 of 10 Posts
