I noticed the thermostat on the Durango faces a different direction than the thermostat on the 300 does that matter? I’m assuming I can just use the 300 radiator which I already have
FWIW you can always check for which year and models certain parts are used using online parts venders like steve white auto. Looking up the crank and heads you can see it is used on many different models and years (up to 2015).
If you don't have an FSM for torque specs go here.
Possibly swap the T stat snout from the D engine over to the 300 unit. The more you can make the 300 engine like the D engine, the easier your install will be.
Good point... may be exactly the same fitment with just a different 'snout' clock position...
Related Threads
Dodge Durango Forum
posts
512K
members
60K
Since
2004
