What is this grinding noise?
3.6K views 40 replies 9 participants last post by  Tin Foil Hat
Just about two days ago, the D (2007 SLT Hemi) started making this grinding noise at speeds of around 17-20mph. It makes this noise while slowing down from a higher speed with or without braking. This noise is independent of AC/fans being on, or foot on throttle/brake pedal, or steering wheel position. As the car slows down to about 18-20mph the noise starts; when the speed drops below about 18mph, the noise stops. There is no noise in the stationary position. However, when the D starts moving, the noise starts again at around 15-20mph and goes away at speeds >20mph.
The vibration of the noise can be felt on the front passenger side floor (see image). I have checked the exhaust manifold heat shield and ruled out the issue of it being loose. It is certainly not the brakes since the sound is independent of the brakes, but based on speed.
I read in other posts that suggested flywheel issues, wheel bearings, brake drums etc. I installed a new Duralast starter motor in January this year (see image) because the OEM part, 56029750AB went out and is discontinued.
See the video below and the image that shows where the noise vibration can be felt.
Here is the video:
Would appreciate any suggestions. Thank you.
Hmmm. I looked up the process to change that flywheel, in case that's the issue - that does not seem like fun to do. How does one diagnose the problem as "flywheel" or "torque converter"?
In the meantime, I've ordered a battery tester so that I can eliminate that as a potential issue if sending power to the starter motor.
I changed the oil today since that's one of the recommended tests in the FSM. I saw that the D had burned thru 1.5qts in 2500 miles - I wonder if that is normal for a 150K miles old car.
Another check recommended by the FSM was a failing oiling pump......
Haven't been able to pinpoint a specific diagnosizs yet.....
I think there is an inspection plate on the transmission housing. I'm not entirely sure, but I've used them on different makes. Chevy,Ford, etc. So, I'm just thinking there could be one. Flywheel issues are tooth related, broken gear, missing teeth. Usually a converter is pretty solid but can wear out the bearings on the input shaft. So, you'll have to get a better idea of the noise first, as pulling a tranny is a major project.
Have you tried jacking up the back wheels and hitting go slow and seeing if you have the noise? Jacking up the front and spinning by hand? Might narrow it down. It would be good if it was wheel or driveshaft noise. CV joints or something.
It sounds like something rubbing to me.
Those oil pumps are easy as to change, by the way.
That starter motor looks really nice.
While your battery could be bad it certainly won't be responsible for any noise in the car.
Reactions: graman and Don Fox
#8 ·
I haven't disassembled any starter motor for this truck yet. But the ones I am familiar with use a solenoid to push the starter motor cog forward to engage the flywheel. If it operates on the same principle, I wonder if something is preventing the solenoid from retracting, or retracting completely? Maybe a bit of casting debris or something in your new starter? Or if there is something electrical keeps pushing it forward? You have a bit of contact there? Does it have exactly the same cog and travel distance as an original starter motor for your car?
Graman:
I recall you have done some fairly serious surgery on this 5.7L re new lifters, etc. Unless you had the engine or trans out, I don't think the sound is TQ/flexplate related.
I am thinking loose exhaust heat shield long the bottom of the floor pan. That sound has also been presented with a water pump on the way out. Just for giggles, remove the serp belt and go for a short spin. If the sound changes or goes away you have narrowed it down big time.
@Don Fox,
Yes - it went thru a major surgery that did not include getting the engine or trans out. I checked the exhaust shields - they're new, and powder coated with SS bolts; they're still good.
That brings me to your suggestion of the serpentine belt removal to narrow it down to the water pump. I have never attempted this - and, the water pump is new, from Mopar replaced in Dec 2023.
But, I'm willing to try the test. So, how does one go about it? Just remove the belt, start the vehicle and drive for a short distance? Do I need to keep the AC/heater in off position? I really like the suggestion, because, like you said, if that sound is not there in this setup, it's a huge process-of-elimination result! Just want to make sure I'm understanding this correctly as to how to do this ...
Thank you!
-Morgan
Hi Morgan:
Before you remove the belt, take a pic with your phone so you can refer to it when you reinstall the belt.
Then rotate the tensoner away from the belt and slip it off of the alternator. Allow the tensioner to relax, then remove the belt completely.
Once the belt is off, and before you start it, wiggle/rotate all of the accessories it drives by hand to feel for up/down or in/out movement, as well as roughness.
You won't want to run it too far or long since the water pump won't be turning, and power steering will be armstrong method lol, but you can make a quick run around the block or down the road, say no more than a mile, and see if the noise remains or changes.
Re the heater, you can run it or not. Without the WP in play, it can't remove heat like it would if the WP were in motion.
#19 ·
Oh, nah fellers. I haven't lived in Australia for 23 years. Been here in Saudi for 10 years now. I work for the army. Saudi National Guard. I like it here. Very nice place with very nice people.
Just picked up a new water pump. I am with my Saudi mate owns the Malibu. Crankshaft pulley seal crapped itself on that. Oil everywhere. We just got the parts.
Sun is setting. We are on our way home, going to get these machines back on the road for tomorrow am.
Fellars??? Where are you from, Arkansas, it's either there or Jersey City NJ? :LOL::ROFLMAO::LOL::D:ROFLMAO:(y)(y)(y)
#30 ·
I think he means the inside part of a cat might be loose. A pretty useless post to have not described it better.
Reactions: graman
#31 · (Edited)
Here is another video. I have put in more details in this video about the vehicle in R/D/P etc. I think the grinding noise is heard more audible in this video - it starts at around 10 seconds into the video. I hope this can be figured out over the weekend with help from this forum. I am going to do the @Don Fox 's suggestion of disconnecting the belt to see if the noise goes away to eliminate a water pump issue. The waterpump is brand new from Mopar that was installed in December 2023.
Thanks in advance!
#32 ·
This sounds like it could be an exhaust rattle to me.
When you do the belt removal, do a video from under the hood.
Be sure to check all of the belt driven accessories for play/roughness by hand when you have the belt off.
#35 ·
UPDATE:
Found the issue! Its the heat shield above the exhaust pipes on the passenger side. The heat shield which seems to be Aluminum, wore out around the washers of the bolts securing it to the body of the vehicle. I may have to put it a wider SS washer along with a heat resistant rubberized washer to hold it in place.
This is on the driver's side. It is still secured and in place, but it looks like I have to go around and put in larger washers on these just in case.... a project when I don't know what to do with my time (which is a long way off) :)
There is also a lot of rust and breakdown because of that on the exhaust system. Does this need to be replaced? For now, I just pushed it back in place....
I have sprayed some rust penetrant to get two of the bolts out that secured the heat shield to the vehicle. Going to get some SS washers and probably some rubberized high heat washers as well to prevent abrasion on the heat shied when I put it back on....
Will post pictures after this is done this evening. ....
