1 - 3 of 3 Posts
2020 Durango R/T 5.7 V8 Octane Red Pearl, Volant CAI
Hey all. Installed my new hitch and running the Curt wiring harness. Neither side is labeled and the instruction tell you to start on passenger side then later on run wiring to passenger side. Anyone know if the yellow wire should be on driver or passenger side? I plugged in and used tester and far right led should be right turn signal but the middle lights up. Confused with instructions and video shows yellow wire on driver's side. Need help if you can.
Thanks!
Think I wired it up correctly. Tester shows the correct signals I was looking for. Just need a trailer to test now. Thanks
1 - 3 of 3 Posts
