1 - 3 of 3 Posts
2006 Dodge Durango 5.7 Hemi, 149,000 miles
the knob options are AWD/4hi/4lo
if i unplug the harness, my mechanic told me my truck would be in 2 wheel drive.. is this true? thoughts on unplugging it??
No, that trasnfer case does not have a 2-wheel-drive mode.
Unplugging the motor will leave the transfer case in whatever mode it is in, and probably set a check-engine light.
JR:
No need to began another post re the same issue. In your previous thread, I believe I mentioned trying to get the T case back into AWD , by cycling the dash switch through it's options, and then disconnecting the connector. As TomK says, that T case does not have a 2WD mode. As the switch is marked, you have AWD/4HI/4LO, and Neutral. Good luck. Hope this works for you.
Reactions: JuliettRoschek
1 - 3 of 3 Posts
