Uconnect CarPlay upgrade
36K views 23 replies 12 participants last post by  PatentlyPhil
Hello everyone,
I couldn't seem to find the thread that had this info in it. I read a few people already did the upgrade but again I couldn't find it so I hope they see this thread and comment or post a link.
I found this on youtube is this what you guys did?
I did it in my 2014. All you need is the radio and the USB hub, and the Infotainment module if you want to keep heated seats/wheel. You need a new rear HVAC control if you want rear HVAC to operate independently of the front. I didn’t care about that for now, so didn’t bother.
The install took about 15minutes and has been working for about 6mos without issue. Best mod I’ve ever done. I got the radio off eBay, and just waited for a good deal. All in, I spent ~$900 and I think it was worth it as I use CarPlay every single time I drive the car.
There are some drawbacks - you lose the remote connection feature with the App. I never used that, so I didn’t care. You also need to call SiriusXM to change the radio code if you have satellite, which is trivial. I think you also lose OTA updates.
Reactions: Chase300
Just curious, what do you mean by remote connection?
Yea, this.
No.
Loving my 2017, but wished I had the Android Auto option. Finally came across a good deal on an 8.4 from a 2021, P/N 68465149AB. Installed it and the new Media hub P/N 68323664AC OE. Acquired the install code from the stealership with the carfax of the wreck I bought it from, its VIN and the serial number of the radio. Everything works...BUT the Android Auto?!
I check the part number and it addresses it as a MULTI MEDIA. Radio Control Unit with GPS Navigation.
2021. Radio Control Unit.
Top it off I can't even find a SW version. All I get in the Dealer/Engineering window is this?
Anyone know what I did wrong? Did I miss something? Leave a part out of my build?
HELP!
#20 ·
Get a radio from 2019 or 2020, assuming you have the 8.4 U-Connect radio now.
#22 ·
2018 will also work - that's what I have.
Be forewarned - the early radios have a known screen delamination issue that requires replacement of the digitizer or the whole display. I opted for the former option when my 2018 unit started delaminating.
#23 ·
Delamination is why I left that year out.
#24 ·
Fair enough. I got my '18 unit before the delamination was ever known about. Mine lasted a long time before finally leaking and worked for more than a year with the bubbles. Replacing the screen was a 5min job and it's good as new.
I wonder if buying a delammed '18 unit and new screen could end up being a cheaper option...
