Uconnect Box Requires Service / Troubleshooting and Fix
7 reading
187K views 594 replies 100 participants last post by  Ghost74
A few months ago I purchased a very expensive car that began to throw a very annoying error into my face since the first month of ownership: "Uconnect Box requires service. Please visit an authorized dealer."
As a naive fool I visited my stealership to claim my warranty and got some insulting experience where a manager performed a small shitshow:
  1. Without looking at the car said that I probably modded something, so they won't cover anything.
  2. Short time after he came again and said they suspect tricky hackers were trying to steal my car with very serious tools.
  3. Claimed they found a problem and fixed it, but the error came back on my next trip.
Long story short, there's a way to troubleshoot this error on any driveway.
Firstly, let's start with the basics. The error "Uconnect Box requires service" means nothing, it actually hides a real reason and displays a generic error for ANY problem that happens inside your telematics box. A telematics box (or TBM2) is a device that is installed above your glove box and sends/receives data to Chrysler-affiliated servers through the LTE antenna without your control over it. It also works as an adapter for the GPS cable that comes to your radio unit from the roof. So whenever a problem happens with your TMB2 (e.g. a signal with a cell tower is lost), you'll see a "Uconnect Box requires service" error message.
Secondly, you need some tools to debug your car. You can use something like AlfaOBD, DiagFCA or JScan. Their price (+ a scanner device by their recommendation) should cost no more than 100 bucks. However, I'm not affiliated with these products, so I can't guarantee their price policy in the future. I used DiagFCA + Vgate vLinker FS for screenshots below to explain how I diagnosed the problem with my TBM2 module.
I connected my cable to the laptop, installed the diagnostics software, connected the scanner cable to the OBD port under the steering wheel column. Then I opened the "Diagnostic" tab and scrolled the list down to the TBM2 module (aka telematics box). You can see on the screenshot below there are 3 columns with names "Active", "Pending" and "Stored" and any non-zero values in these columns indicate issues that present right now or happened in the past:
Then I clicked on TMB2 module and went to the DTCs tab to see actual error codes. In my case that was B1560-13 (Cellular Antenna 1 - Circuit Open), but other owners may have slightly different codes:
After that I found a document with a name S2108000085. It's a TSB that explains where the TBM module is located, how it looks, how to test connectors and where wires are put in your car. So I grabbed my trim removal set, ratchet wrench socket set and went to my car. I gently removed the weatherstrip and a bunch of panels and eventually dropped the frame of my glove box. You can see that the telematics box is sitting on the top of it:
I inspected cable connectors on the back and was initially sure that my problem is the connector #3 if we count from left to right. But after poking around, I confirmed it works OK, just looks bad. My problem was the cable #4: I removed connectors one by one when the engine was off, then I started the car and scanned errors to see if I get new errors. When I removed the connector #4, I didn't get any new errors but B1560-13, so I understood that this cable is my problem.
Then I decided to find the opposite part of this cable. It didn't look like it goes to the radio unit, so the only place where it can go is probably the fin on the roof. I dropped a few panels and found this blue connector:
I wiggled it a little bit and my next error scan came clean, so I understood that my problem is a loose connection between two wires in this blue adapter/splitter. I used a zip tie to stop movement of both halves and so far it works for 3 weeks since then, the error never came back.
I hope this information will save someone's time because I see a huge amount of people on forums like this that are waiting for mysterious Uconnect updates that can't fix hardware issues like the one above.
#548 ·
The saga continues……@GBDurango! The telematics box, antenna and wiring have now all been replaced and now my speakers work intermittently even after one of those was replaced ONLY after the service manager witnessed for himself the sound issues. I am BEYOND frustrated by all of these issues. @DodgeCares I will be reaching out to find out what recourse I have.
#558 ·
If you're still within your 90 day warranty then they should cover it but just don't expect it.
Reactions: Sweekes18
#560 ·
Update on my Uconnect Box error issue - admittedly it's only been two days and three separate trips in my Durango AWD but there have been ZERO Uconnect requires service by an authorized dealer pop ups and I am hopeful that replacing the radio has fixed the Uconnect pop up issue. There are features in the radio that I had forgotten I had that now work. I have pasted the work order below in case that might help someone else who can bring this to their dealership and tell them to step up. I am grateful that my dealership, Albrecht CDJR, covered the $600 radio replacement under their goodwill program, and for a great dealership like this one, their goodwill program doesn't expire with the warrantee. They wanted me happy and went all in to make that happen. In addition to working with a large customer obsessed dealership, I recommend getting Uconnect involved to create a "star case" and engaging @DodgeCares so all are aware and aligned. I will post back in a month if the fix holds, and sooner if our Uconnect nightmare continues. Best of luck to all who are still looking for their fix.
#563 ·
Thank you for this update! We take your feedback seriously and will pass it along to the appropriate team.
Diamond
Dodge Cares
#561 ·
Can't read your document.
#566 ·
See attached PDF
Reactions: bb37
#570 ·
  • Love
Reactions: Vice-White
#572 ·
Update on my radio replacement to fix the Uconnect Box requires service pop up alert. I know there were skeptics out there and YOU WERE RIGHT unfortunately. I had four days of no pop ups and then on day five she's baaaacck. Now it comes up about once a trip which I am going to live with until one of you talented engineers out there documents a bullet proof fix and Stellantis uses that to announce a recall. It's obvious that they can't figure it out and/or they don't see any upside to fix this issue for Dodge and Jeep customers. The writing is on the wall with electric I guess, but until they make an eclectic that sounds and feels like my 8 cylinder hemi, forgetaboutit. You are spot on @JC Hemi, this is a great group.
#574 ·
My 2022 dodge Durango has been saying this since I purchased it. I asked about it several time at my oil change and tire service appointments that took place at the same service department where I purchased the Durango. They told me they could find nothing wrong with the vehicle. the message does pop up pretty frequently. And most of the time the everything with my Uconnect works perfectly. But there are times when I’ll get out turn off the Durango, and when I get back in it doesn’t matter what I do my phone and the vehicle will not connect and it could be a day or a couple weeks before they do again.
#576 ·
We're sorry to hear. Feel free to send our team a private message for an extra layer of assistance.
Diamond
Dodge Cares
#580 ·
#592 ·
Dealers all know now about the issue, it is antenna or TBM. They are just playing dumb.
#585 ·
It's the cables from the radio to the telematics box and maybe from there to the sharkfin antenna.
#587 ·
They probably just got cables with better connectors on them.
Reactions: JC Hemi and Vztech
#590 ·
All FUconnect software is buggy.
