241 - 260 of 274 Posts
Use at your own risk ...
UC5_U31.42_NSE
Thanks, I've just tried the Zip file with the firmware, but the machine can't see it. Most likely MY24 is an Atlantis system , not a PowerNet like MY21-23.
Now I'm trying a 32GB flash drive in Fat32 and unpack the Zip file. But I am more than sure that the firmware is not suitable.
Then keep running it and you should be fine. What is the issue you think you're having?
I don't like the FM radio; the reception is very poor. I compared it to the Land Cruiser 300, which picks up ten FM stations, while I only get one, even with the cars parked right next to each other. I have more questions about Off Road Pages.
Did the FM reception get noticeably worse or was that what you were trying to fix?
I'm confused. You put a UC5 radio in to replace your UC4 radio? If so, how did you get it to fit? Your issue could simply be that the FM antenna is not properly connected or that it doesn't fit the UC5 radio.
Believe me, it's not that complicated. The only caveat is that the donor must be a 19-21MY Dodge Durango connected to the stock UAQ display. Uconnect 5 from WL is not compatible with WK2. The Canbuses are different.
UC5 is only available in the 10.1 screen radio. If you didn't install that then you don't have UC5.
