Maybe a bad starter/solenoid?
I figured that would throw a code, and im not receiving one. if it doesn't that might be the case. thanks for the recommendation.Maybe a bad starter/solenoid?
yah that sounds more like the RF module not reading the key fob that my buddies have dealt with. once mine is started it continues to run, without issue. it doesn't give me the "no fob detected" on the dash when I initially go to start it.Posted earlier about a start then die issue .. similar in that my brake pedal goes stiff as well.
