Since I'm in the market for a new to me Gen 3 D, I wanted to create a thread regarding the oem Tow Group. If you are ordering, you can simply check the box. In my case, I don't buy my vehicles new, so I have a little extra homework to do regarding finding a D with the Tow Group.
From what I have learned, the Tow Group has evolved as time has gone by, from the Gen1, to the Gen 2, and now the Gen 3. I had also read that if the Gen 3 in question has the rear bumper hitch cover/bulge, that it has the Tow Group.
I have found this statement to be inaccurate, as I have run a number of VINS on Ds with the bumper cover panel/bulge, and Tow Group is not listed on the build sheet!!!
Do your due diligence, and be sure of what you are buying! Don't take the dealers/sales Rube's word for it!
As of '20, it appears to include the following:
Priced at $1195.00
Class IV receiver hitch
Trailer brake control
Rear load leveling suspension
Heavy duty engine cooling
Full sized spare tire
Note that the latest version includes a built in brake controller, which I find to be an excellent upgrade.
Both my '01 and '04 D's had the available Tow Group for their time.
For '23, we are also seeing comments about folks getting the "donut" non full sized spare, or no spare at all when they have spec'ed the Tow Group.
For the Gen 2 Durangos:
"Straight from the 2004 Durango dealership brochure..... "Trailer Tow Group - Includes hitch receiver, seven- and four-pin wiring-harness, and 6"x9" power, heated, foldaway exterior mirrors. V8 equipped vehicles also receive a 750-amp maintenance free battery, auxiliary transmission fluid cooler and power steering fluid cooler."
My '04 also was pre-wired for a brake controller. I have installed one since I have a trailer with dual axles, and brakes on the front axle. The trailer brakes make quite a difference once you get some weight on the trailer.
I believe that the Tow Group for the Gen 1's was similar.
One thing that surprised me, is that none of the Durango Tow Groups includes a shorter axle ratio. The Gen 1s and 2's could have 3.55, which was the standard ratio, or upgrade to 3.92. The shorter gear, was not part of the Tow Group though.
For the Gen 3 D, the 5.7L Ds have a 3.09 gear, and the 3.6L Ds have a 3.45 ratio, whether or not the Tow Group option is applied.
The Tow and Go package includes these goodies:
"The $5,495 Tow ‘n Go kit equips the Durango with a Class IV hitch, four- and seven-pin trailer connectors, inbuilt trailer brake control with native cluster display, self-levelling headlamps, active damping suspension, 20″ wheels, and a bunch more. Hauling is amped up with an upgraded 180 amp alternator, heavy-duty engine cooling, free-flowing performance exhaust, beefy R/T performance Brembo brakes, and an electronic rear limited-slip differential geared to a modest ratio of 3.09. All-in, this boosts the Durango’s tow rating by 1,300 lbs to an unmatched 8,700 lbs."
Note that the axle ratio for the Tow and Go is still 3.09.
The SRT Ds come with a 3.70 ratio.
This information is not guaranteed to be 100% complete, but it is a good place to start for someone looking to understand what the oem Tow Group has included through the years.
Remember, that Dodge limits the Durango to 3500 pounds or less if the oem Tow Group is not installed when it was built.
The R/T models have some of the Tow Group upgrades as part of the 5.7L option, but not the hitch/harness.
The forum has seen quite a few instances where disingenuous "stealerships" have told prospective buyers that a given D sans the Tow Group, can be upgraded to it's full tow rating, "by throwing a hitch and harness on it."
Per Dodge, this is 100% "Buffalo Bagels" as Colonel Potter would say!
It's my intention, to have folks throw in their real world experiences, and have this be a "one stop shop" so to speak for Durango towing in general.
Priced at $1195.00
