1 - 7 of 31 Posts
John to Lower the D 1/2" up front, crank counterclockwise 3 cranks and back up 1 on each torsion bar bolt
to drop it 1" , crank counterclockwise 5 full revolutions and back clockwise 1
Every 4 equals 1" But you always want to be adjusting up not down!!
The Rear can be lowered with the use of a Block on top of spring under axle but beware sometimes vibrations occur afterward just ask Warren!
Neil Each rotation is a 1/4" difference That's why you adjust up.
Every other D here has been 1/4" per rotation.I guess each torsion bar is different
Some of the AWD D's experience some driveline vibration with lowering more than 1"
Should take you about half an hour to do!
NEIL NOTICE THE WORD SOME IN MY ABOVE STATEMENT!
I didn't say all. Also as Warren stated some may not be as picky as others.
:cheesy:
Just posting it as a warning some get a bit out of hand and then cry the blues about ride and vibrations.
You Must be kidding Warren I can't actually have been right!
It has to do with what style driveshaft they have and those angles.
1 - 7 of 31 Posts
