have a question about tire pressures.
I went to check the pressure in the tires the other day. first thing I did was read the sticker on the door and it said 41lbs for the rear and 35 for the front (thought that was a bit strange cuz of the big difference?.) then, while filling up the tires, topping them off a few pound to the spec on the door, I read on the actual tires that they should be 50lbs cold (They were cold).
the tires are Firestone Destination LE`s.
my question is, which pressures do I use? the one listed on the door or the suggested pressure on the actual tire?
