1 - 6 of 6 Posts
My Citadel has intermittent errors with the front right tire. It will read for a while and then not read anything on that tire. Any ideas?
Needs a new sensor on that tire. Might as well do all four at the same time.
Reactions: DuRonbo
TPMS battery life is typically 7 years. That sensor is failing due to battery and the rest aren't far behind. As stated above replace all four sensors.
RockAuto is your friend for sensors cheaper than the dealer. That includes Mopar OEM sensors. Denso sensors are a good value and the OEM supplier.. Avoid Dorman at all costs.
Hi Tappel,
We sincerely regret to hear of the trouble you are experiencing. We kindly recommend following up with your local dealer on this if you are not able to determine a solution based on suggestions provided here.
Rob
Dodge Cares
So one of my DD tire pressure sensors seems to have gone bad as well.
Question to those who have replaced the sensors, Do I need to do any programming / learning if I put the Denso ones? Or just drive for sometime and truck will auto relearn?
1 - 6 of 6 Posts
