Re: Mopar RTVs
Volphin said:
Use Mopar black for engine oil apps. Orange for diffs and Trans RTV when needed. They're different formulas for a reason. I found a Permatex that's the same as Mopar Gen 2 black. Same smell, color and properties. I bench tested it. If I find the PN I'll post it. This is important as the Mopar Gen 2 has a one year expiration on the tube. Permatex stock is going to be somewhat fresher. Maybe Joe can shed some light on why?
Bill
Almost all RTV uses the same chemistry to cure, and acetic acid (that vinegary smell) is a by-product of the cure mechanism. Some of the proprietary high-end RTV's (GE Silicone II for example) use a slightly different mechanism and the odor is different.
As to your choice of color for application, I'd use the Mopar Orange under the hood (and maybe the transmission) and the Black for the diffs - just the opposite of your preference, Bill.
The Orange RTV is more likely a temperature resistant grade. The color is probably the result of an additive designed to give high temperature performance. It's probably in the Black as well, but unless it's specified in the components listing, you wouldn't know it. For Automotive grades however, both the Black and the Orange will have an additive that helps resist degradation from contact with oils and lubes. Black Bathtub Caulk won't have this additive so you can't rely on color to tell the additive components.
So, to make a long story even longer, the Orange will give you both high temp AND oil resistance while the Black will most likely have Oil resistance but not necessarily high temp resistance. Regardless, make sure you use automotive grade not your normal household sealant.
As to expiration, that's up to the manufacturer (or packager.) Unopened you may be able to use a tube more than a few years down the road. Once you've opened a tube, it'll start to cure almost immediately and be useless a few month later.
Hope that helps.
Joe
