1 - 18 of 18 Posts
Taillight guards
I picked up a pair of metal taillight guards really cheap.
How are they attached to the D? will I need to drill holes in the body and use sheet metal screws? there are 2 tabs on the guards.
I know it's a stupid question but I just want to make sure before I start drillin into the D. :?
They should line up with the existing Taillight screws
They kinda hook on one edge and screw into where the lights are screwed into Body
No Drilling should be required
hmmm, maybe these won't fit then :cry:
the 2 tabs don't come anywhere close to the tlight screws.
they have the right shape and do fit well tho, so I don't know. I'll take another look at them.
Other methods are 3m auto motive tape
Discussion Starter #6
midnite said:
this may sound stupid, but flip them over?, you may just have them upside down or opposite way. don't mean to be a D!ck, but that's the only thing I can think of. if not ask the place you bought them from
your not bein a D!ck :p. I'll check that again but they really only look like they go on one way.
I bought them at a garage sale. They old lady didn't know anything about them except that they were for a D. They have the correct shape of the gen 1 D1`s T-lights so they're not for the gen 2s.
The ones I put on my 4Runner had to be drilled. The 3M double-sided, foam sticky tape (black is the weather-proof version) works VERY well, too?
Yes, they should fit by the existing taillight skew holes. A rear pic of Furious showing the driver's side. You can see that their only going to fit one way, following the shape of the lens.
Edit: Found another photo
:mrgreen:
-Steve
Discussion Starter #11
thanks for the pics?
the mounting tabs on mine don't look like that :(
here are some pics.
there's a tag there but all it says is "off road accessory", "light guard", 2008104, 253059, void if removed. :?
a search online for 253059 yielded this link :
http://www.autopartswarehouse.com/mmp/dodge~durango~tail_light_guard~parts.html
Looks like it should work, but those tabs don't line up to any existing screws on my D :?
It does look as if those will need to be drilled in by the inside edge of the taillights the brackets also look bent a bit
It look like you might want to pull off one of the headlights to see if it mounts to the backside of the taillight somehow, and sorry, it doesn't look like 3M tape will work to well on this one.
For the price of a set of new ones? I'd pitch those. No way would I drill holes in the lights when others don't need it. Plus, those are a little rusted, etc. Just ditch them and the headaches and get something new that works and installs in 5 minutes.
JMHO
IndyD
Discussion Starter #15
thought about trashing them but I got them really cheap at a garage sale. new ones are pretty pricey.
I'm not worried about the rust, I was gonna have them sandblasted clean and then repaint them the color of the D.
To much trouble and not worth it. Just get new ones. You'll have more in those that aren't perfect in time, labor and costs than getting perfect new ones. JMHO.
IndyD
It'll cost a bunch to get them painted up nicely to match the D but It'll look Great! As long as they're not completely corroded (metal damaged) I say clean em up sand em real nice few coats of primer and Spray the color of the D.
Keep us posted how it turns out
do you know where I can find 2004 Dodge durango tail light gaurds? I’ve been looking everywhere... or do you know if any other cars trail light guards will fit?
1 - 18 of 18 Posts
