Don't have an answer but apparently there are different windage tray designs to accommodate different strokes on the gen 3 engines. Although what I find interesting is if you look up stroker kits for the 5.7 there is no mention of needing a different windage tray.
However, apparently MMX makes a custom windage tray for strokers. You might try contacting them to see if you may need one for your application?
www.modernmusclextreme.com
Hemi Stroker Engine Custom Windage Tray by Modern Muscle Performance
