How do I check that?Have you checked that the blend door is functioning properly? If that's hung up, it'll never get cold.
You'll have to check it with either a very good scanner or take the HVAC apart. The actuators are known to break and more than one door has fallen completely off (which causes what you're experiencing).How do I check that?
All vents blow hot when I set the heater to full HIGH (hot), and all vents switch from hot to ambient when I switch to full LOW (cool), so it seems the doors are working. Unless I'm misunderstanding what the doors do...You'll have to check it with either a very good scanner or take the HVAC apart. The actuators are known to break and more than one door has fallen completely off (which causes what you're experiencing).
There is one door that switches from the heater core side to the a/c side. If it's stuck or the actuator is broken, it will blow a combo of both hot and cold. Might be a trip to the dealer.All vents blow hot when I set the heater to full HIGH (hot), and all vents switch from hot to ambient when I switch to full LOW (cool), so it seems the doors are working. Unless I'm misunderstanding what the doors do...
FYI there are a couple of TSBs regarding AC performance for 2014 durangos.Got a DIY AC recharge kit and used the pressure gauge to check low pressure port, with engine running, AC on Max with recirculate engaged. Pressure indicated ~40 psi on the gauge (middle of the green zone).
Ambient temp about 62, and the vents in the front only got temps down to 67-77 (depending on which vent you checked). Rear vents only got down to 68.
So, weird noises, pressure seems ok, but AC isn’t blowing cold at all.
Compressor? Other ideas?
Those are not accurate...you need a set of professional A/C gauges.Got a DIY AC recharge kit and used the pressure gauge to check low pressure port, with engine running, AC on Max with recirculate engaged. Pressure indicated ~40 psi on the gauge (middle of the green zone).
