1 - 6 of 6 Posts
I have a weird issue with my starter.
As soon as I turn the vehicle to the on position it turns on I don’t even have to go to start. And the starter just stays on and won’t shut off until I put it in drive. I have 2 CEL codes p1389 and p1768.
I have replaced the ignition switch and cylinder
the relays for the auto shut down and the starter.
and reseated and cleaned the PCM connectors also reset it.
the only thing I can think of is a issue with the shifter going into park or the PCM has gone faulty.
any help would be appreciated also if this is in the wrong area I am sorry I’m new here.
Yes i have a similar issue:
2014 durango hemi.
Occasionally, When i push button to start, the starter
continues to turn over but engine does not crank.The only way to stop the starter is to put it in any other gear.
I have to contuine this several times until it finally cranks.
Guy at local Dodge dealer
said put in a fuel additive at every fill up.
Just the 2 of us have this problem?
Anyone get to the bottom of this?, I have the same issue with my 06 Durango 5.7L
Cranks in the on position, with a new PCM
1 - 6 of 6 Posts
