1 - 8 of 8 Posts
Writing to report my first 'issue' with the Durango.
All tires still are within 'green' range (35 and 37 psi) as far as pressure. I did not check the spare but something tells me this is not about psi anymore. Any chance I can fix this at home? I would love to avoid the hassle of scheduling the appointment...
Thanks!
Made an appointment with the dealer to have it looked at on Wednesday. I will be sure to give them the part number you listed (56029542AD) to hopefully make the diagnosis and repair process a bit easier.
I will update this thread with results as well.
Thanks!
Discussion Starter #4
Update: the warning and the dashboard light are both... gone. Just disappeared during a short ride to the bike trail today. I guess the only thing I can do now it to watch for the warning to re-emerge. If not, I will have to cancer my Wednesday appointment.
I wouldn't cancel the appointment. I'd be hopeful that they can still read any codes that had ben thrown. It will come back. Ours did the same thing a couple different times. And it always came back until it was replaced.
Sometimes you have to drive a bit for the system to reset. Up to 20 miles in some cases.
Will be good to know the resolution is the same as the "Schizo".
Took delivery of a 2015 about 2 weeks ago & the TPMS warning for system service appeared after about 3 days of ownership. Tires are actually over inflated as delivered at about 43 psi. Am ignoring for now & will schedule service when I take it back for the license plates and/or what ever nit-noys appear before then.
At least the display provides the individual tire pressures. Have a friend w/ a > 5yr old Rav-4 that just gives a warning & then you have to hunt. Since it has a full size spare w/ a sensor, you have 5 things to check.
Discussion Starter #8
It's been almost 3 weeks now for me, with no repeat error message to report. I hope it stays that way, knock on wood.
1 - 8 of 8 Posts
