Replace rear differential
2.4K views 8 replies 6 participants last post by  Don Fox
Needing to replace my rear diff on a 2003 D, I know the ratio, I know the sizes, only thing I don't know is the difference between a 4wd and a 2wd real diff, if any. All of the parts replacement apps that I have seen with the exception of one, do not even ask if it is 4wd or not. Hate to sound confused, but I am, lol.
HG1010:
Your 2003 is 4x4 correct? From my research some time ago, I found that the Gen 1 Durangos equipped with the part time 4x4 T case got the larger 9.25 inch rear end. I figured this was because the rear would be seeing 100% engine power/torque when in the 2wd mode. On the other hand, the full time 4x4 (AWD) D's got the smaller 8.25 inch rearend, as it would never see more than 60% engine power.
Either one will fit, and work for you. You have the 3.55 gears?
Joejoe:
Welcome to DDN.
In order to provide useful information, it would help to know the issue you are dealing with, or are you trying to do some sort of performance upgrade?
Do
