1 - 4 of 45 Posts
You can arm the OEM withe aftermarket unit if you need,Not tricky to do
Thr Viper is what I'm using as well,No problems
Viper 160 keyless remote starter has Great range
Viper 5900 has Alarm and starter pager SST with a mile range
Rick
Not anymore Steve
These a bypass module out that with do the samething without losing a key
And his 99 won't have that Sentry Key (gray plastic)
Rick
The OEM alarm will sound if you open the door.
Not if they Break the glass
Not if the Unbolt the rims
Just to name a few things
Wire codes for you just in case you feel like doing it yourself
Rick
12volts red or pink/black + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition dk. blue + ignition harness
Second Ignition
Third Ignition
Accessory black/orange + ignition harness
Second Accessory black/white + ignition harness
Keysense
Power Lock orange/purple + blue plug in driver kick
Power Unlock pink/purple + blue plug in driver kick
Lock Motor orange/black drivers kick panel
Unlock Motor blue drivers kick panel
Parking Lights+ black/yellow
Notes: Located at a black plug in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blk/blu & tan/red -
Notes: The black/blue catches the drivers door and the tan/red catches all other doors. Use both wires and diode isolate each.
Dome Supervision
Trunk/Hatch Pin tan/black -
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green/orange -
Disarm No Unlock
Tachometer black/gray ignition coil
Wait to start
Brake Wire white/tan + at brake pedal switch
Parking Brake
Horn Trigger black/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
1 - 4 of 45 Posts
