Ready for a road trip to Knotts Berry Farm.
4K views 20 replies 6 participants last post by  dizzyD
The final touches were done on our D today and it's all set for a road trip to Knotts Berry Farm. It's about a 7 hour drive from Tucson.
Here's what was done over the past few weeks and today:
Brake fluid changed out.
Brake pads checked. OK.
Upper and lower radiator hose changed out. Air bled from system.
Windshield replaced. The old one had a crack on the edge that was creaking when backing out of our driveway. Creak is gone.
Underhood seal installed. Missing after accident repairs.
Front lower belly shield installed. Missing after accident repairs.
Crack in the top of the grill repaired. Cosmetic only.
4 new tires mounted and balanced.
4 wheel alignment.
Oil changed in late January. Low miles since then. Oil still looks great.
Washer fluid full.
Power steering fluid full.
Coolant full.
Boots on front suspension parts look good.
Front shocks checked and are good.
IsoHeet fuel drier put in tank.
Did I miss anything?
Serpintine belt condition?
transmission fluid level?
differential fluid level?
have a great trip to the park, sounds like your all ready to go!!
Ron
Ron
Ahhh. Yes. Belt looks good. I asked about it at the dealership and they said it was fine.
Transmission fluid has been changed out 2 times in 56,000 miles. ATF-4 put in both times. Level looks good. No leaks of any kind from underneath.
Front and rear differentials along with the transfer case where changed out about a year ago. Front differential was slightly overfilled. I just had it leveled off a few months ago. They had to remove some.
looks like your all set then, just bring along fort knox for gasoline, and your gonna have a great time. I'll be ridin my D up to reno around the first of march to see my brother who just accepted a job there. Really cool because he's been in Euclair wisconsin for the last 11 yrs, and I haven't seen him since he left. lookin forward to it!! good luck on your trip!!
Ron
Ron
Yeah, I know. Lots of money for gas. Plus we're going to use the roof rack so even worse mileage.
IndyDurango said:
Check the air in the tires. Put it at 40lbs in each for the trip. Just because they were balanced, doesn't mean they're inflated correctly.
Also, why the wheel alignment? Was it out of whack? I've never had mine aligned.
Have fun on the trip :!:
IndyDurango
I did have to add air to the tires. I put them up to 36lbs. You recommend 40?
The old tires had a lot more wear on the inside. They were so bad that they were causing it to drift to the right. My wife curbed the tires quite a bit in the past. The alignment was off but I'm not expert. I don't know how off it was.
#8 ·
Lower radiator hose close to the fan.
One final question. Does anyone know if it's normal for the lower radiator hose to be less than 1 inch from the fan blades? I replaced the hose myself. It's an OEM hose. Everything fits just fine but it sure seems close.
It's a very close fit on my 4.7 as well
I have about 1.5" clearance.
Belt changed.
Ok, I replaced the serpentine belt myself. The old one wasn't cracked but after 56,000 miles it had glazing. I did it without tools. Getting the old belt off was easy. Putting the new one on was difficult until I figured out that I should put the belt on the tensioner and then pull it up to the A/C pulley. Once I did that it was perfect.
Your gonna forget to stop by my house, If your coming interstate 10, you'll drive right by my house! Once you cross the 15 and 91
Yep, I-10 I think. Either that or I-8 and up through San Diego. It's only about 20 miles more to go I-8 and I-8 is a lot less crowded plus we don't have to go through Phoenix. We're still deciding though.
If we go I-10 is there a Durango specific honk? I don't think we'll be stopping. I gotta get the kids there fast or they'll explode.
#14 ·
I know! :roll:
We're here in Buena Park right now. We ended up taking I-8 to the 805 to I-5. The wind was really bad. At one point we were going uphill against the wind and getting 5-6 mpg. We filled up in San Clemente and paid $3.39 a gallon for 87.
Our average mpg was around 12 or 13 except for the uphill against the wind areas. We had luggage on the roof rack so I'm sure that lowers the mpg a bit.
Knotts Berry Farm was fun. They sure added a lot of coasters. The last time I was there was in 1984.
Braved the rains, did ya!
#17 ·
Glad to hear you had a safe Journey
#20 ·
We're back home now. We left at about 8am Tucson time and got home by 4pm. No problems at all.
I did find 2 more cosmetic problems. One was a missing bolt that holds the front lower plastic spoiler/air dam to the metal bumper. I was able to find a replacement that had the right size and thread pitch. All is good with that now. The other item is a missing round plastic cowl fastener with a torx or star on it. I can get one from the dealership.
thomsonc said:
I like Knotts Berry Farm- better than Disneyland in my opinion. I found there are less people there; a lot of the tourists from Asia pack Disneyland.
Knotts is soo much better, But is soo much smaller than the Dizzyland park. Dizzy's california adventure is the new side, primarily the adult side, even though they have a few kids stuff, But love knott's! Also I stay away from Magic mundtain! That place get's Nuts with the Highschool Kids during summer! The last time I was there, I had to be evacuated, (2+ years ago)
