I'm trying to locate the rubber bushings that slide onto the ears at the top of the radiator where it bolts to the upper support as well as the two the bottom pegs slide into. I lost mine when I ripped out the old motor so I need to get replacements. Since I'm at work right now, I don't have access to my FSM to check on what Dodge may call these, other than the obvious assumption of "rubber bushings".
I've check parts.com and rockauto.com with no luck so, if anyone has insight or a source, it'd be much appreciated. THANKS!!
