FYI, I took some shots of the engine compartment and pipes. It's kinda hard to see the TB & M1 under the airhat and all the tubing & wiring, but they're there. The headers are the most obvious addition and I must say it's nice to see the ceramic coated headers instead of the rusted stock exhaust manifolds.
The undercarriage shot is from the back and shows the 3" crossover from the driver side header which connects directly into left side of the x-pipe. The right header is routed directly via a 3" connector into the right side of the x-pipe, which is then connected to the Spintech muffler which has two 2.5" outlets which are split (left & right) with slashcut circular tips at the rear.
