Ok 88 octane is actually just a fancy way of saying e-85 which is gas with ethanol and I don't suggest running it through the vehicle unless the engine is specifically designed to be able to use it because you will tear up the engine that wayI have a 2004 Dodge Durango 4.7. I've been told by others that I could and probably should use the 88 octane fue. My questions are has anyone used this fuel in a Durango and ended up with problems, and can it be interchangeable with 87/89 if 88 isn't available while traveling? Any information is appreciated.
