1 - 6 of 14 Posts
4.7L PCM can't ignore the PS switch. 4.7L wiring harness always has a connector for the PS switch, IIRC it splits out of the big harness at the base of the branch that goes to the engine-oil-pressure sensor.
I'd assume this vehicle would have always been popping a code if the switch wasn't there.. unless it was never driven over 40MPH.
what is your build date (the MDH code on your door sticker)?
I don't see any evidence that 03 4.7's were ever built without the switch, but 04 4.7's do NOT have the switch.
reading the description of the OBD code in the diagnostic manual, I have my doubts that will fool the PCM.
If you have that wire in your harness, then you should have the switch connector as well; I don't think they'd put in a wire to nowhere..
It is PCM connector C3 pin 30, and also pin 10 in C105 near the PCM (that will be the easier place to get at it)
...tom
sorry, clipped you the wrong C105 location drawing.
All 2003 4.7L's have a 4-connector PCM. You should have the wire.. Check C105 to see if it has a dark-blue/orange wire in pin 10..
I just wonder where the wire goes.. I can't believe there would be a wire that doesn't at least end up in a disconnected connector..
If you make it to some get-together that I'm also at, ping me and I'll bring a tone-tracker to see if we can figure out where it goes..
The PCM test happens after driving above 40MPH for some amount of time (I forget how long, 30sec I think) .. so drive a bit on the highway to make sure it behaves..
...tom
1 - 6 of 14 Posts
