1 - 4 of 4 Posts
Hey guys I noticed on a recent road trip that my passenger side blind spot light is not working. I am not getting any sensor errors. I am wondering if its just a bulb that burnt out. Before I start tearing into things I thought I would check to see if anyone else has had this happen.
The optional Blind Spot Monitor (BSM) system used in this vehicle has two control modules. One control module is dedicated to each side of the vehicle. A Blind Spot Module (BSM) is integral to the Left Blind Spot Sensor (LBSS) or Right Blind Spot Sensor (RBSS) for the same side of the vehicle.
View attachment BlindSpotSensorRemoval.pdf
do you get the alert (if enabled) if you hit your turn signal with someone in the blind spot?
Also having this issue on my new 2019 Durango GT. Driver side light works, but not on the passenger side. Chime works on both sides. Maybe it’s a loose connection behind the mirror?
Hoping it’s a quick fix at the dealership.
1 - 4 of 4 Posts
