1 - 3 of 16 Posts
The TPS going isn't uncommon. When it does it'll affect driveability and rpms. Replace the TPS.
DavidBarron said:
OK, I'm sold. I'll put in a new TPS. Kragen has one for $50 with no "intercooler". I can't see anything that looks like a little radiator on mine, so I assume I don't need that, right?
And for the record, the D was fine today, and the MIL went off by itself tonight?
Concur with Steve, WTH does intercooler have to do with the TPS? Shop around. The TPS used to be cheap. Semi recently the price spiked up, but according to posts it's still $20-$30 at some places.
I don't understand what you mean driving for 11 months with a stored code? If a code is present, the CEL lamp will be illuminated. If the problem is corrected, the lamp will go out and the code will be in memory for a short peroid (I forget how many starts it's supposed to be) If you clear the code (disconnect the battery and turn the key to on for 30-45 seconds) It'll erase the code from memory and will turn the light off. If the problem is still present, the light will come back on.
1 - 3 of 16 Posts
