1 - 4 of 4 Posts
Please Help
I have a 2000 dodge Durango 5.9 that keeps over heating, I've change thermostat, water pump and sensor. but it still overheats what else can I change or check to see if it will work.
Also check to see if the outside air passages thru radiator aren't clogged.
I changed my radiator our recently and noticed (especially if your radiator leaked) How clogged up the fins were.
It's most likely the Radiator. the insides coat up and stop working as efficiently. is is all of the time, or just towing? it might be the fan, but mine started overheating towing on the highway. Replaced the radiator and all was great.
1 - 4 of 4 Posts
