Not getting to temp. sometimes...weird issure
1.4K views 9 replies 6 participants last post by  myersml564
I have a 2013 durango crew v6 with 106k miles. just replaced water pump and thermostat and radiator cap. It gets to temp while sitting in garage and idling with air/heat off. When I turn the heat on the temp drops to about 170. While i'm driving it the check engine light comes on with the message that it is below operating temp. If I turn heat off the temp will raise again. I do get hot air but only while the temp is up closer to operating temp. I've burped this thing like all the different ways I've read on here. I'm stumped...any ideas.
From what I recall from my old v6, i thought the thermostat housing is actually interference based, meaning you can't seat the thermostat in backwards. It sounds like it's bypassing, meaning either it's not seated right or the thermostat is bad. I completely agree with Don Fox's question about it being a no kidding OEM Mopar thermostat. I tried two "performance" thermostats on my old v6, both had the crimped seal on the thermostat pop out and lead to bypassing and not coming up to temp erratically.
Reactions: Don Fox
