1 - 13 of 13 Posts
BigAl
I bagged my 2016 R/T over the weekend but need to replace the rear shocks since they are load leveling. What is everyone using? I heard part number 68299126AA is the stock non load level but I cannot find a for sure answer, any other shocks being used?
not trying to thread jack... but interested in same part...
I have a 2011 D Crew currently with the NON LOAD LEVELING shocks... would Monroe part#911304 fit my Crew and would the load leveling work after installation?
Discussion starter · #4 ·
They are Monroe part#911304. I happen to have a brand new set with the upper mounts that I'd sell you. PM me if you're interested.
Tanks for the info, will keep this in mind
I actually want non load leveling shocks, that particular part number is not load leveling.
Discussion starter · #9 ·
I changed out the load level shocks in my 300, ride didnt change at all.
With my air suspension I have sensors so it will auto adjust to my designated ride height with load leveling shocks it can cause some issues and its better to run standard shocks.
Reactions: 11earl
Shock mount Dorman 523-031. Rear Non Load Levelers Mopar 68069846ah or 68029551ag
I just put the Mopars on got them from Rock Auto i think igot a bad one thou im getting a thumping. I going to swap out to the Monroes 911304.
Did the Eibach springs so far not impressed might be to soft.
I have a 2016 D Limited and need to replace the rear shocks (non load leveling). It appears that the Monroe 911304's are only for 2011-2015 D's, at least according to the Monroe website. Can anyone tell me if those will work on the 2016 or if there is another after market shock that will work? I've been looking at the KYB's also but I am having a hard time finding a consistent part number on the KYB's.
I was looking to do this on my 2016 WD R/T. So you think the EIbach springs are too soft?
Does the drop with the springs look good?
Did you ever get confirmation of this? Looking to do the same. Thanks.
1 - 13 of 13 Posts
