Checked the fan?
You're correct on the clutch catching and roaring when it gets hot, it has been doing that. I checked the electric fan last night. According to my 01 FSM, the electric fan should come on either when the engine get to a certain temp(can't recall the exact number) or when the A/C is switched on. I assume it'd be the same for 2003. I turned the key on and turned the AC off. Then started the truck?no electric fan movement. I then turned on the AC, still no electric fan. Killed the engine, checked the fuse in the PDC for the fan, it appeared to be good. Pulled the relay for the fan, tapped it a couple of times, popped it back in and then started the engine with the AC off. No movement from the electric?then I cut the AC on, and the fan started spinning. The fan appeared to not be spinning as fast as I think it should, but that could be because I was looking thru the clutch fan as it was spinning, optical illusion kinda thing?but it still didn't sound loud enough while running.
Cut the AC off, fan stopped, AC back on, no movement from the fan. Tapped the relay some more, couldn't get the fan to spin again.
Definitely something with the electric. Could dripping coolant have shorted a connector or the fan motor?(The upper hose was leaking, hence the replacement)
I suspect a bad/sticking fan relay. Gonna go find a replacement for it this morning.
I assume autoZone/Advance auto should have a replacement relay?
Anything else I should look for? wiring? connections? etc?
Guys you don't know how much I appreciate everyones help with this!
Thanks!
