Mopar intake install issues
17K views 43 replies 10 participants last post by  BlkDRT2014
Just installed the mopar intake on the 14 durango r/t. Couple questions. First off, the plastic clip on the washer resovoir, how do you get it off? Right now I just have the heat shield without that bracket. Next is the m8 bolt for the bracket on the actual inlet tube appears to be too short, anyone else have this happen? Looks like I just need to get a longer bolt.
I had no issues with the intake system it fit like a glove when lined up. As for the engine cover it takes a good whack to get it to lock down. wet the insides of the grommets very lightly with some wd 40 sit them on there and give the cover a whack over each one, it will lock down.
Yea, it definitely fits great. I bought it used so I think the m8 bolt for the inlet tube was just the wrong one. Was the supplied bolt longer than the stock? Also, what did you use to get that plastic clip from the resovoir off? Need to go buy a trim removal tool to see if I can get that bit*h off. So far it looks awesome though, just don't want to drive around with the two items not resolved.
Funny thing. I asked my Dodge dealer today to get me a price on a Mopar CAI for my 2014 R/T. He said it isn't in the catalog. Do you guys have a part number I can give him?
I don't know about a part number but unless I'm mistaken the same one from 11-13 should still fit the 14's. Someone back me up here?
#14 ·
Sad that customers know more than the "experts"!
Yeah...don't even get me started on the "experts" working behind the counter at 99.99% of the parts houses (Auto Zone, Discount Auto Parts, Advanced Auto Parts, O'Reilly Auto, etc) across America.....
#17 ·
In case anyone was wondering, got a longer m8 bolt. Still doesn't work, appears that the hole is either stripped or the bolts are not correct thread. Going to try some different bolts again today. Wonder if I use some loctite if it would help? Not sure what else to do here.
#18 ·
Thank you dbtx!
Reactions: dbtx
#22 ·
You must have installed something wrong. Hopefully you haven't pinched or cut a line causing the pressure loss.
Go back and look over the instructions. Take some pictures so we can see what you are talking about.
#25 ·
Just because the bracket is loose for the PS reservoir it should not be leaking. Check and make sure the hose clamp is not loose or you did not crack the reservoir. Did you tighten it down super tight when you put it back together or something? If so it is possible you might have cracked it. I don't have my D yet to look at for comparison so it is hard for me to tell if the bracket off the side of the reservoir is an integrated piece of plastic or it is something separate.
Don't keep running the truck with little to no fluid, you are going to burn something up. Figure out where it is leaking and try to fix it.
Like was said, take some close up pictures of the reservoir so we can see what you have going on.
#30 ·
Espi,
Ok, like I said, I don't have mine yet to look at for reference but I believe you are showing a picture of your Power steering pump. I see a black hose at the top with a constant pressure clamp on it attached to a silver 90 degree elbow tube going to the pump. Where this piece meets the pump it is somewhat elliptical and it looks like there is a bolt missing. Was this like this or did you remove a bolt from this location when installing the CAI? That is not a bracket. It is the connection to the PS pump. If you removed a bolt from that location put it back in. I am assuming this is where you are talking about it leaking. Kind of hard to determine from your pic.
Also, you don't have to get it towed. Put Mopar ATF+4 (or equivalent), that is the proper fluid for the PS system. If it got super low and and has air in the system it may feel weird when moving the steering back and forth. Simply leave the cap loose and, it fill it to proper level (engine off) and turn the steering back and forth (engine running) slowly from lock to lock and it should force the air out if it got that low. Turn the engine off and check the fluid for correct level.
#31 ·
Blkdrt,
Thanks. I tried putting the bolt back on. Took it off because that is where the inlet tube for the cai attaches. Unfortunately, that fin bolt won't tighten down properly. Feels stripped but not sure. It's crazy because its only the first time the bolt came out. I have the fluid to put in, but without the bolt tightening down, the fluid leaks everywhere. So frustrated.
#32 ·
Ok, I found the instructions for the CAI and see that bolt was to be removed and replaced with another one, that obviously is missing from the used CAI you got.
If you move the bracket for the CAI out of the way, will the original bolt go back in and tighten down? If so, you are ok and have not buggered the threads on the pump housing. From looking at the instructions there is another bolt, longer than the one that is in there to accommodate the extra thickness of the CAI bracket. If you measure the thickness of the bracket (washer if that is part of the install) that should give you a good idea on how much longer of a bolt you need.
Take the original bolt to either a Lowes or auto parts store and figure out what the thread count is an whether is metric or standard. Then look for the proper length bolt in the proper thread count that matches the original bolt. If you are trying to use the original bolt to tighten it down over top of the CAI bracket it is not going to be long enough and will not catch the threads.
Are we closer now to the problem you are having?
