1 - 20 of 30 Posts
2021 R/T Tow N Go Redline
Is it me or am I missing a part here? Is there supposed to be some ducting here? I can see the cabin air filter just sitting there. That doesn't seem right. It's a 2021 R/T TnG
Vehicle Car Hood Automotive design Motor vehicle
2021 Durango RT AWD Town'NGo
Same here on my 2021 TnG. Any idea if they have a shortage of that part? the scary thing is that all the water drain is there. I bet that the filter gets wet. Also, if you use the AC in recirculating mode, from where it takes the air? Dodge, anything to say?
Discussion Starter · #4 ·
I guess it's not just me and could be shortage related then? The filter seems super vulnerable to damage there. Should I take it to the dealership?
Regarding recirculation, i think if you do that it just doesn't suck air from the filter. Blocks it off and just takes air from the cabin
2021 Billet R/T TNG
Hmm, had not noticed that. Will have to check mine. If there is supposed to be something there, it would be a QC issue and not a supply issue though.
Discussion Starter · #12 ·
2021 Durango GT Plus AWD
Same on our newer '21 GT Plus model. One of the first things I noticed this past summer after we got it home and I popped the hood. Looks really odd, and like maybe it would get wet or damaged, but so far, no issues. Will be monitoring it as winter winds down. If I see any issues, back to the dealer under warranty. That, and add to the Medium heated seat setting not working like many others here...:(
LTRaven's explanation means that you will not get a dealer to do anything about it because it's designed that way.
Reactions: OurZoo
1 - 20 of 30 Posts
