1 - 20 of 24 Posts
Does anyone know the factory lug nut torque spec for 2016 with balcktop 20s? It does not appear to be included in the owners manual.
Thanks!
Yup. But I have the big 800 page manual that you have to request, not sure if it's in the smaller manual.
Sent from my VS987 using Tapatalk
130 ft-lbs ?!? Really? Okay in my small 2014 owners guide in the glove box (not the manual on the DVD/CD) all it says is 110 ft-lbs for the steel spare. Is the 130 ft-lbs specification for all and any of the factory 18" and 20" aluminum wheels?
Okay I just found this on-line;
http://cdn.dealereprocess.com/cdn/servicemanuals/dodge/2014-durango.pdf
On page #528 it clearly states the lug nuts should be torqued to 130 ft-lbs. I wonder why the two Chrysler publications disagree on this safety related specification?
Well I went out first thing this morning and made sure they were "GutenTight". Not much movement in the torque wrench going from 110 ft-lbs to 130 ft-lbs.
Lol... early morning smart ass moment sorry about that. Torque 'em down, then after 20-30 miles of driving torque them down again. They'll come loose if you don't retorque, learned that almost catastrophically.
No, I didn't think you were being a smart ass. Hell, I thought it was funny and sort of appropriate, considering that MBZ was involved with the design and engineering of the uni-body / chassis of the 2011+ JGC and Durango. In my mind I could see a little old German engineer in a lab coat, sort of like Professor Irwin Corey saying "Ya Gutentight".
From what I've gathered, the standard wheels should be torqued to 110 Ft. lbs and the spare should be torqued to 130 Ft. lbs.
I was confused by the owners manual as well. It states 130 but that's in the spare tire info section. When I went to Discount Tire they torqued to 110.
I'll be using the 110 spec. 130 seems a bit overkill.
I torque mine to 150. Same as I do my F-150. You’re fine going to 150 on these. They’re pretty good size lugs studs.
IMO no danger of that at 150. I torqued our 2012 citadel to that many times and did our 18 to that when I rotated the tires a couple months ago. A lot of shops put wheels back on with impact anyway and that’s a lot more than 150.
1 - 20 of 24 Posts
