1 - 5 of 5 Posts
My 2013 Durango Citadel has 3 quick beeps that is different than the chime when it opens and closes. Currently the power open and close is not functioning, just the three quick beeps. I can hear the unit try to open/ shut. It can be opened and shut manually. I checked the fuse and it is in good condition and the battery to the vehicle is in good shape. Any ideas of what may be causing the fault?
Try replacing the strut on the right side. It may be weak making the hatch too heavy for the motor to lift it.
That strut is okay. I'm pretty sure the issue is with the lift-gate motor(as it's called by Mopar). I removed the lift-gate motor and with it still connected to the wire harness pressed the lift gate button. The lift-gate motor retracted an inch or so and stopped. I have a new one on order.
Mine just started doing the same thing. Did you figure out what the issue was?
Hi bruker,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist.
Rob
Dodge Cares
1 - 5 of 5 Posts
