21 - 26 of 26 Posts
After reading this thread, I’m glad I didn’t get the sunroof on my GT 17. My bald head is glad too.
had this issue. The issue for me was a pinch in the drain tube. Before I discovered the issue, I wasn’t able to clear the tube using compressed air or a few attempts to physically clear it using wire, an electrician’s glow stick and even a homemade mini drain snake using a bicycle brake wire and sheath hooked up to a drill- frustrating! Then, I popped off the A-pillar trim and noticed the tube was kinked about where the dashboard and the A-pillar met. I jimmy-rigged a sleeve to go around the tube at the pinched section by cutting about an inch of copper pipe (e.g., the pipe used in home plumbing) and then cutting it one side using a dremil tool. I then used a snap ring tool to expand the sleeve enough to put it around the tube, then squeezed it into shape with pliers. This caused the kink in the tube to return to perfect round shape, thus fixing the issue. Air and water passed through the tube no problem. I learned during the process that the tube dumps the water through the firewall and the outlet is visible (at least on the passenger side) with the hood up. It was a pain to figure all of this out, but with this knowledge I think it would be a very quick repair- hopefully this benefits someone!
I get drips coming from the sunglasses holder and the water runs down the right side A-pillar into the electronics behind the passenger side kick plate. That makes the HVAC act up. I can't find where the water is coming in, it really happens when I go through the carwash. I have poured water down the drain tubes and it comes out by the front mudflaps, nothing inside. I have had my windshield replaced and I think they set it in too far. I'm wondering if that's the problem.
2022 Dodge Durango RT, destroyer gray, 5.7 Hemi
So I just bought a 22 Durango RT. I take it to the car wash and at the dryer cycle, water drops get sprayed on my face. I take the truck back to Dodge and they ordered a whole new sunroof. It took almost 4 weeks. I take it to the same car wash and it’s still doing the same thing.
Is this common?
21 - 26 of 26 Posts
