Year and a half ago or so, I noticed a few drops of tranny fluid under the D one morning. I looked, and one of the transmission lines where the metal ties into the fitting and converts to rubber was leaking right at that junction. I wiped it clean and before I did anything about it, the leak stopped. I knew that wasn't going to last.
Anyway, fast forward to last week. The dripping has started again, this time in earnest. It's leaking constantly now, leaving fluid everywhere I park. I looked under it this morning and it's leaking at the same junction again. It's leaking much more heavily now. Until I get it fixed, I will not drive it. It will certainly rupture and strand me and I won't take that chance. So here's the reason for the thread...
What repair is available for this, short of getting a whole new line? Are replacement fittings and rubber hose assemblies available? Is it possible to cut and paste a double clamp bypass and get rid of those seemingly weak links altogether? I know those lines operate under fairly heavy pressure, so I don't want to hack repair it. But, if a double clamp fix is acceptable, I will go that route.
Anyone have any experience with this particular issue?
