The rear jack points are obvious but I can’t find the ones for the front?? See pics. Anyone know the proper jack lift spot for the front ?
I use the flat frame like parts of the unibody close to where the transmission cross member bolts on. DO NOT jack it on the L shaped bracket just in front of this area. You can see it in the picture. That is a very weak sub frame support that will bend easily and cause a terrible creeking noise in your front end. Believe me, I know from experience. There's a thread on it somewhere here.The top pic is the rear with the large jack abutment, the bottom pic is the front behind the front wheels - no lift abutment in sight for miles -
