You didn't bother to give it headers and/or a SRT or other 3" exhaust? Is this just a mild build then or just a base power add? You'll have to post a list of all the parts you used and their sources along with a tale of putting it together. If the 5.7 can withstand it I would think this would be about the best power add you can do to one, if it's reasonably easy to do. It sounds like the cost is way below that of a Whipple.The internals are stock with stock exhaust.
That's the new 3.0L Whipple I believe. Whole kit is like $8500 or something like that. Not much more power you can give it with out risking a trans failure first.You didn't bother to give it headers and/or a SRT or other 3" exhaust? Is this just a mild build then or just a base power add? You'll have to post a list of all the parts you used and their sources along with a tale of putting it together. If the 5.7 can withstand it I would think this would be about the best power add you can do to one, if it's reasonably easy to do. It sounds like the cost is way below that of a Whipple.
nopeIt says whipple on the blower?
Headers and exhaust would add another 50hp.
I've been thinking of adding this same setup to my 2020 SRT. Didn't that installation require a new PCM installation?
